Dynamark 12HP
Russ Hartranft
03-26-2000 15:52:26
The only way I can get my mower to start is to jump the solenoid. Turning the key will not turn the motor over. Doe this mean I need a new switch????? or what???
Dave G
02-21-2002 18:30:10
 JD300 tiller question in reply to
Ray VanDervort
01-22-2001 18:20:18
 Re: Dynamark 12HP in reply to Russ Hartranft, 03-26-2000 15:52:26
http://home.stny.rr.com/vandervort/index.htm
It means that the circuit from the batery thru the key thru the interlocks is faulty. This means it needs service. It is rarely the ignition switch, more often the blade engagement or foot pedal safety switch.
sean faulkner
06-13-2002 15:25:16
 Re: Re: Dynamark 12HP in reply to Ray VanDervort, 01-22-2001 18:20:18
hi, i have the same problem with my dynamark 12hp 39 in. cut.. i would like to know where the blade engagment, or the foot pedel safety switch is i would like to know where they would be... thank, sean faulkner
P mcG
07-08-2006 16:48:00
 Re: Re: Re: Dynamark 12HP in reply to sean faulkner, 06-13-2002 15:25:16
Mine has a 15 amp fuse under the the control panel. It always blows when I connect the battery. Yours might be blown. I also had to clean the commutator inside the starter motor. Thought it was a weak battery, but carbon builds up where the brushes contact. Use two flat pieces of wood like paint stirrers to hold the brushes down while reassembling. My Dynamark has a dead man switch under the seat. If the blades are engaged and you get off the seat it kills the engine. Hope this helps.I need advice on shifter problems in previous post.
M.Blais
03-28-2000 17:53:46
Before you replace the solenoid, make sure that when your turn the ignition to the start position you have power on the small tab of the solenoid. If you do, chances are you solenoid has to be replaced. If you don't have power, the problem could be with your ignition switch or the clutch/seat and or PTO switch. Did you check the fuse between the switch and the battery ??
M.
SMB
03-27-2000 08:04:29
It's probably your solenoid. Or, it could be the wiring, but I'd just about bet that it is the solenoid. SMB
Jeff Ziegler
11-23-2000 19:05:18
 Re: Re: Dynamark 12HP in reply to SMB, 03-27-2000 08:04:29
I also have an old Dynamark 8HP,with a 36" snow thrower attachment and am looking for a dealer that can oder 2 new belts from. Do you know of any one that may be able to help.
THANKS.
Pete in ks
03-28-2000 11:05:15
Ditto!
