Cub cadet 149 hood question
Murray D.
04-05-2000 10:18:51
Recently acquired a cub cadet 149 hydro. Doesn't seem to be anything to hold the hood when open. It just opens until the hood and grille castings meet. It binds on the hinge an bit and I'm wondering if there should be a rod/chain/cable to take the weight?
M Huffman
04-07-2000 04:14:01
 Re: cub cadet 149 hood question in reply to Murray D., 04-05-2000 10:18:51
I have a 149 that the ower before me took a pull cord rope and tied it to the cross part on the hood then tied the other end to the motor lift hook on the motor. the lenght was just enough to go past 90 deg. so it would not hit the front of the front of the tractor the rope will not get into any thing or so for it has not.
Jon
02-04-2002 19:13:09
 Cub Cadet Ignition Switch in reply to Murray D., 04-05-2000 10:18:51
Fish
02-10-2002 13:15:58
 Re: Kohler starter drives in reply to Gene Davis, 02-10-2002 12:39:44
Kohler and Onan are two different engine manufacturers, but gunk on the helical drives
of any starter would cause the problems you have
described. Carb spray would probably be a good start. Fish
Jim S.
04-06-2000 06:11:50
No, that's the way they are made. I like to stick a rag there to prevent it from hitting the casting. Also have used that gray foam pipe wrap insulation as a buffer there. If you don't mind modifying it, a chain is a great idea, but I wanted to keep mine original.
