Cub cadet belt
Terry
04-13-2000 18:30:11
Need to know size of belt that goes from engine
to mower deck on Cub Cadet model 102 thanks
Paul
04-15-2000 06:41:32
 Re: cub cadet belt in reply to Terry, 04-13-2000 18:30:11
A Cub Cadet dealer should have the belt, or can get it. The CC belt will last longer than a normal belt because of the twist and turns the belt goes through, they are designed to do it, and should last several years longer than a normal V belt. A normal V belt is only designed to operate in a Straight line (pulley to pulley) so to speak, and not with the 90 degree twist that you need. With that said, I understand a "Gates Green stripe" will give good service also, but have not used them.
SMB
04-13-2000 18:43:33
Go to www.ihcubcadet.com There is a board there where you may get an answer.
