Case 190
missery
04-23-2000 08:16:18
i need to find an axle shaft for the left rear drive wheel.is there any way i can find a parts catolog on the internet. any help would be welcome. missery.
Herm
04-23-2000 09:57:58
 Re: case 190 in reply to missery, 04-23-2000 08:16:18
The part # probably won't do any good . If the axle is bad , but the wheel flange is OK , a machineshop could cut the flange off and you could use a 150 axle for the shaft using your flange . The 195 axle has the correct spline , I think it will work , but it has a disc on it for the 195 brakes . Herm
