16hp briggssraton
Rick Shafer
04-24-2000 16:51:13
I have twin cyl. 16hp briggs&straton that I can not get to run right unless I keep it almost fully choked.What could be wrong?
GARY BRION
07-15-2002 12:26:02
 Re: 16hp briggssraton in reply to Rick Shafer, 04-24-2000 16:51:13
YES THERE IS AIR GETING SUCKED IN FROM SOMEWHERE ON THE CARB MANIFOLD OR ONE OF THE GASKETS. TRY TUNEING THE CARB FIRST THERE IS A SCREW ON THE CARB WHICH CONTROLS THE AMOINT OF AIR DRAWN IN TO THE CARB TRY CLOSEING IT DOWN THEN YOU WILL FIND IT WILL RUN WITHOUT CHOKE. THATS ALL THE CHOKE IS DOING IS SLOWING DOWN THE AIR FLOW GOOD LUCK GARY
Mike
01-04-2001 17:24:23
Car needs to be blown out with an air compressor, mine did the same thing on my racing lawn mower, i took it off blew it out and it worked jsut fine,
Jim S.
04-24-2000 17:19:56
From most likely to least likely, easiest to hardest:
1.) Blocked fuel line/shutoff valve/filter.
2.) Varnished carb...time for a cleanup and rebuild.
3.) Improper timing/worn points.
4.) Blown head gasket.
5.) Sticking intake and/or exhaust valve.
6.) Extremely worn rings. (You'd see blue smoke way before this, though.)
