Ariens 16HP Hydro
Doug
04-25-2000 19:28:30
Is there a way to adjust the transmission so it doesn't creep in neutral? I have to play around with the lever all the time and you can't leave the tractor running in neutral or it will move.
Mr.B~MI
04-26-2000 04:16:00
 Re: Ariens 16HP Hydro in reply to Doug, 04-25-2000 19:28:30
Doug -- I am not familiar with this tractor but most do have adjustments on the pintel shaft and are sort of a spring loaded centering device, Most have a roller that is forced into a depression that is on the leaver or linkage going to the trans. Some times you need to tighten the spring pressure and in other cases the depression is worn out so that the roller does not sit tightly into the depression, in other cases the roller may be worn or its mounting pin is loose allowing it to wander. Also the leaver on the pump some times comes loose allowing the pintel shaft to move in relation to the leaver. I have seen the problem to be internal in the drive pump But I hope that is not the case here. Beyond this I guess I can't help. Good Luck, Mr,B
Sam
05-19-2002 15:05:54
 Kohler MV16 twin won't start in reply to Doug, 04-25-2000 19:28:30
Bill
03-31-2002 07:09:29
 Onan 18hp Twin Carb Adjust Help in reply to Doug, 04-25-2000 19:28:30
