AC 912H
Pete in Ks
04-26-2000 08:16:27
Working on a Alis 912H Kohler (K301) 12hp. The engine is very tired and has beeen rebuilt numerious times and is ready to be retired. Is there a replacement engine that will work in this tractor. I would like to find one that didn't require the cutting fitting process if possible. Anyone know of a direct fit replacement?
HARRELL
04-27-2000 12:41:47
 Re: AC 912H in reply to Pete in Ks , 04-26-2000 08:16:27
I HAVE A USED K301 (12HP)THAT IS COMPLETE LESS CARB.IT CAME OFF OF A IH CUB CADET.IT HAS NOT EVER BEEN REBUILT AND STILL RUNS.
Mr.B~MI
04-26-2000 11:06:10
Pete, There plenty of engines that could be used without a lot of changes. The way to do it is take the Engine model and spec number to the engine dealer of your choice and he has books that check for interchangeable engines. other used engines may be able to be found but you may have to use your own judgement on that one. Many of the similar Kohlers will bolt in. When it comes to using another brand-- then you need to go to the books and then you still may not get all the answers. Mr.B
