14 HP CARB.
HARRELL
04-27-2000 07:01:28
I NEED A GOOD CARB. FOR A 14 HP. KOHLER SINGLE CYLINDER K321 ON A 1450 CUB. THANKS HARRELL
Mr.B~MI
04-27-2000 16:09:52
 Re: 14 HP CARB. in reply to HARRELL, 04-27-2000 07:01:28
Just for the record I am sure you can get new carbs that replace that one. It is rare to find one that is not worn that has been in service for a while as those engines do viberate quite a bit and the throtle shafts and body wear out. If your shaft and body are good then just overhaul yours. Good luck, Mr.B~MI
Jim D
04-27-2000 18:58:04
 Re: Re: 14 HP CARB. in reply to Mr.B~MI, 04-27-2000 16:09:52
Kohler offers a "kit" to repair worn carbs like yours. ask your Cub Cadet dealer to get you one,they are reasonably priced and will get you back to like new again.
