Cub cadet...Loss of power under load
D Stiteler
05-01-2000 09:24:22
I have a cub cadette (1250 hydrostatic) that just recently loses power while going up a slight grade while mowing, I put in a new spark plug, adusted the carb as per instructions, but no change, I was wondering if the compression release mechanism went bad, I'm not familiar with this but the decal mentions this engine detail, wondering if anyone else has had a similar problem with the loss of power.
Thanks for any input.
Pete in Ks
05-02-2000 06:08:57
 Re: Cub cadet...Loss of power under load in reply to D Stiteler, 05-01-2000 09:24:22
I would fist check the points. Clean or replace and reset to specs. If the points are not set properly you will experience a loss of power.
Jim S.
05-01-2000 11:32:06
More likely causes than ACR problem:
1.) Leaking head gasket.
2.) Carbonized combustion chamber.
3.) Carbon under valves.
4.) Burnt and/or sticking valve (usually exhaust).
5.) Governor improperly working/mis-adjusted.
6.) Restricted fuel flow.
7.) Sticky needle valve and/or float in carb.
8.) Leaky carb to block gasket and/or loose carb to block connection.
Hope this helps. 1250 is a nice tractor!
Joe Runnels
05-29-2000 22:34:19
 Re: Re: Cub cadet...Loss of power under load in reply to Jim S., 05-01-2000 11:32:06
No doubt you have solved the loss of power problem by now. However I experienced loss of power, then shut down under heavy load. Would restart with choke, and run fine until next heavy load. Solution, replaced engine mounted fuel pump.
WHAT A GREAT MACHINE.
