212 deere Variator?
Herb
05-29-2000 19:42:01
The clutch pedal has been coming up very slowly.Is there an adjustment to be made to corect this condition?
Leo
05-29-2000 19:55:51
 Re: 212 deere Variator? in reply to Herb, 05-29-2000 19:42:01
Your Variator needs a bit of lubrication, like WD40. I have to do mine about once a year. Follow the book, get one of the belts out of the groove, squirt a little of WD40 at the bottom of the groove near the center pulley(the part that slides back and forth between the pulley outer walls). try to wiggle the center sliding part over one or the other to get the benefit of the lube. put back together and you notice the improvement. Usuall takes laying on your back, looking up through dark inwards into bright sky..some fun :) But the variator is the coolest. Leo
herb
06-09-2000 20:31:54
 Re: Re: 212 deere Variator? in reply to Leo, 05-29-2000 19:55:51
Thanks Leo
