Cub cadet 7272 deck belts
Radcliff City M
06-09-2000 05:43:20
During the past year sometime the type of material used in the deck belts for the 7272 belly mower has changed. The new belts are a slick type surface and the design seems to have been altered.
Since this change has occured we have been going through a large increase in the number of belts per month that break.
These breaks are very clean as if the pressure on the belts just pull it apart as if it was cut.
Is there anyone out there having the same problem?
Please respond if you even think you are using a lot more belts. Cub is not willing to make any compensation for the extreme number of the belts used.
Yes, We have sent the entire tractor to the cub dealer. They replaced some of the parts on the deck , to include some brand new ones we knew were not bad
UNHAPPY
