Cub Cadet Model 123
Ricky
01-15-1999 17:42:15
Info needed on how to fill transmission with fluid. There are no plugs or fillers. Auto transmission. Any help appreciated.
Dave W,
04-29-2002 19:37:52
 Re: John Deere 112 in reply to john, 04-29-2002 06:04:10
try BL4440@netint.net he's in western Iowa
Kenneth Updike
01-16-1999 05:50:05
 Re: Cub Cadet Model 123 in reply to Ricky, 01-15-1999 17:42:15
There is a pipe plug located on the rear cover above the drawbar. This is where you fill and check the oil level. It holds 7 quarts of HY-TRAN hydraulic oil. DO NOT USE: Dexron II, ATF, Trans Fluid, use ONLY HY-TRAN!!!!! Change the spin on oil filter too!!!!! !
