14HP craftsman runs and shuts off
DS
06-18-2000 14:36:16
I have a 14HP crafstman riding mower that has a briggs IC engine. The problem I am having is that it will run for an hour then it shuts off and will not restart untill it cools down. Any suggestions?
otis
11-22-2003 20:54:32
 Re: 14HP craftsman runs and shuts off in reply to DS, 06-18-2000 14:36:16
the points have a pin that pushes them when it gets hot it swells and sticks open.
Tractor guy
06-28-2000 17:13:50
Absolutely could be a clogged fuel cap breather.
But more important check for mouse nest under the shroud those buggers like to fill up your cooling fins with whatever is available to them causing the engine to overheat. They also like to chew the insulation off mag wires and ground wires. If the mag wire is chewed replace the mag, if the ground wire is chewed tape it so it doesn't ground against the engine.
Condo Carl
07-02-2000 10:42:26
 Re: Re: 14HP craftsman runs and shuts off in reply to Tractor guy, 06-28-2000 17:13:50
Well sears didn't show up when they said so i fixed it myself..It was the coil(ign. mod.) same thing. Sears wanted $88.00 just to come out plus parts went to local kohler dis. and the part cost me 37.00 Hope this helps .....
Condo Carl..
Condo Carl
07-02-2000 10:41:42
Condo Carl..
scott
06-06-2002 20:18:26
 brigg 11 hp crankcase gasket re-assembly in reply to Tractor guy, 06-28-2000 17:13:50
condo carl
06-24-2000 15:38:17
Am haveing the same problem with a 14 hp kohler.
Runs longer with the hood off,but when it dies there is no spark untill it cool down. Almost like a resetting relay. I can't find one but have a sears man comeing out next wed. (unless i can fix it before then) Will let you know what i find out..
p
06-20-2000 13:35:32
Does it have points? If so then it could be the condensor.
SMB
06-19-2000 08:16:55
Could be a clogged vent in the gas cap-thus creating a vaccum.
