Carb rebuild
Lisa
06-19-2000 11:37:14
Does anyone know other than replacement how to repair a carburator that has an extremely worn throttle shaft? I'm referring to Kohler engines but assume all engines may have this similar problem. The mower runs descent right now, but has to be sucking in dirt thru the worn shaft.
Jim S.
06-21-2000 08:15:15
 Re: carb rebuild in reply to Lisa, 06-19-2000 11:37:14
Kohler makes a rebuild kit with a new shaft and bushing. The Kohler Service Manual ($8.50) has complete instructions on how to install the kit. It ain't rocket science.
Dean
06-19-2000 14:37:33
Any decent carburetor repair shop can help you. Usually it involves replacing the shaft and/or drilling out the body of the carburetor and installing bushings. Good luck!
