IH Cub Cadet Hydrastatic Drive Fluid
AC Powell
06-25-2000 07:18:24
I have a 1250 International HarvesterCub Cadet What kind of fluid can I use in my hydrastatic drive other than IH Hy-Tran fluid? And why does it stop working when it gets hot?
Thank you.
AC Powell
Jim S.
06-26-2000 05:49:00
 Re: IH Cub Cadet Hydrastatic Drive Fluid in reply to AC Powell, 06-25-2000 07:18:24
I'd start with the simple stuff. Have you replaced the filter with a genuine IH filter and refilled with Hytran? There is no substitute for Hytran, that's what Sauer-Sundstrand designed the hyrdo units to run with. Do you have your plastic fan intact on the driveshaft? Is the unit clean and free of excessive grime and oil/dirt?
Excessive heat buildup may have made a crack internally that opens when the castings heat up, allowing an internal fluid leak. A worn charge pump unit, trunnion shaft passage and/or swash plate pistons internally could also cause the problem.
