Briggs Engine problem
John
06-27-2000 12:03:19
I have a 14 hp briggs engine on my rider..I started it up ..then it let out a huge puff of white smoke!!! I checked the oil and found out that it had gasoline in the oil ...what should i look for?? I ran the engine for only a min...did it do any damage ??? please help with this problem ..any help will be greatly appreciated..... ..thanks again John
p
06-27-2000 12:31:10
 Re: Briggs Engine problem in reply to John, 06-27-2000 12:03:19
If you have gas in the oil then you have a sticky float. Take off the bowl on the carb. and give it a good clean and make sure that it stops the fuel flow when it is level with the carb itself. You might even put in a fuel shutoff valve before the carb to stop the fuel flow. This is a somewhat common problem. Don't worry about the damage to the oil. flush out the system real good and let it dry out, leave it all open for a while and runs a quart of oil trhough it to flush. Refill with 30W and run it.
b.roberts
10-28-2003 11:45:41
 Re: Re: Briggs Engine problem in reply to p, 06-27-2000 12:31:10
fuel pump located on top of motor is leaking through entering through valve cover and down oil return holes replace fuel pump
