Ford YT16H deck belt
dan
07-12-2000 17:53:05
I have a ford yt16h w/ a briggsII 16 hp twin and a 42" deck (#9441). does anyone know the belt model between these two? the last people at a J.D.
shop just put a close one on. didn't last.
Jerry
07-06-2002 22:52:50
 Re: Ford YT16H deck belt in reply to dan, 07-12-2000 17:53:05
I just replaced mine. Tried a couple and finally found that a 48" X 5/8" belt from Autozone seems to work great.
Tip: make sure that your deck is level and the idler pulley mount is not bent and the belt is not rubbing anywhere.
Hope this helps.
Karen
04-14-2002 07:28:47
 Bantam tractor in reply to dan, 07-12-2000 17:53:05
Joe K
07-23-2000 08:43:38
Re;you YT posting,Belt for YT16 Ford:
Main Drive for tractor-Ford 216594
Deck Drive Belt-Ford 235000
Main 103.25x1/2
DeckDrive-50x21/32
Aftermarket Main- Carquest/Gates-6378 Deck drive- Carquest/Gates-6950 Hope this helps
GEO
07-14-2000 17:46:06
Why did the belt not last? Are you using mower belts or just plain commercial belts?
dan
07-16-2000 11:13:50
 Re: Re: Ford YT16H deck belt in reply to GEO, 07-14-2000 17:46:06
the belt was put on at a john deere shop, I would suppose they would use the right kind. they told me they didn't know the exact model number and just put one on that was close enough. I'm hoping to find the right belt number and order it.
thanks for the help.
GEO
07-16-2000 19:09:05
 Re: Re: Re: Ford YT16H deck belt in reply to dan, 07-16-2000 11:13:50
Is the problem belt the mower drive belt from the engine or the belt that is on the deck itself. I have a 17hydro with a 48 deck.
