444 Case Mower Deck
Dan
07-14-2000 23:15:34
I have a 444 Case GLT. Does anyone know the model number for the belt or hyd. driven mower(s) that fit this tractor.
Jack
07-19-2000 10:09:02
 Re: 444 Case Mower Deck in reply to Dan, 07-14-2000 23:15:34
J-46 or L-46 48" mowers will fit. I just bought an L-46 deck and installed it on my Case 442. These decks are somewhat scarce!
Max
08-09-2000 19:00:02
 Re: Re: 444 Case Mower Deck in reply to Jack, 07-19-2000 10:09:02
You should be able to go up to the M46 and get the discharge chute kit for the HY-Vac. This is a real nice way to beef up the discharge area. It is a brace that is welded over the discharge chute so that the foot bar can be removed. I think the N46 deck comes with this already on it. Anything after that I beleive has the left hand discharge, but I could be wrong. If you have the Hydraulic PTO, the new rear mowers should fit with no problem. The only attachment you may not be able to use is one of the log splitters which take the 5-quart reservoir (plastic one under the dash).
