446 ENGINE PROBLEM
DOUG CLINE
07-17-2000 18:37:32
I AM HAVING A PROBLEM WITH KEEPING THE GARDEN TRACTOR RUNNING. IT WILL START, AND RUN A VERY SHORT TIME THEN STALL. IT DOESN'T WANT TO START AGAIN UNTIL IT SETS AWHILE. I HAVE CHANGED CARB PARTS, COIL, PLUGS. ANY IDEAS WILL BE APPREICIATED.
THANKS
MAX
08-09-2000 18:30:33
 Re: 446 ENGINE PROBLEM in reply to DOUG CLINE, 07-17-2000 18:37:32
The 446's had problems with the carburator float and the condensor. The condensor is easy, just replace. The float should be a brass one for the other type gets ate up by the gasohol and other aditives and swells up in the float bowl.
Beitz
07-19-2000 18:23:55
Make sure your gas cap is vented...And don't forget to change the condencer....
