Cub 129 Engine problem
Scott McDearmon
01-18-1999 19:31:16
My 129 has a 12HP Kohler, recently rebuilt. The problem is with the governor(?) High RPM the governor works back and forth, 1/4 throttle works fine. Replaced the carb and adjusted, same thing. Internal governor gear and weights are working correctly. Also, at high RPM, no load, muffler turns red, but high speed needle is adjusted correctly. Any ideas?
JOE MURPHY
01-19-1999 19:58:08
 Re: Cub 129 Engine problem in reply to Scott McDearmon, 01-18-1999 19:31:16
HERE ARE A COUPLE THINGS TO CHECK : SOME OF THE KOHLER ENGINES HAVE BALANCE GEARS ,WERE THEY PROPERLY TIMED ... TIMMING- CAN BE DONE WITH A TIMMING LIGHT (MUFFLER GETTING RED). CARB -THROTTLE SHAFT WORN INTO CARB BODY
