Briggs model 8 will not start
scott barlow
07-24-2000 17:59:16
has spark and gas to plug but will not start
dave
07-25-2000 16:31:04
 Re: briggs model 8 will not start in reply to scott barlow, 07-24-2000 17:59:16
Shearpin in flywheel has slip and broke pull your flywheel and put in a new one. Dave
p
07-25-2000 14:48:59
Is the spark plug wet with gas, or is it just in the carb?
Beitz
07-24-2000 18:17:20
One of your valves is most likly stuck open...
Jim S.
07-25-2000 09:37:42
 Re: Re: briggs model 8 will not start in reply to Beitz, 07-24-2000 18:17:20
First, be sure points are at .020 so that the spark is coming at the right time. Spark should be blue in color at plug tip when testing. Yellow spark indicates bad points and/or bad wire connections.
Then take plug out, put thumb over hole, pull it. If thumb "poofs" off hole, it has compression, but may have low compression due to leaky head gasket. If no "poof," blown head gasket and/or valve is stuck, could possibly be a hole in piston.
Small engine man
07-29-2000 06:36:05
 Re: Re: Re: briggs model 8 will not start in reply to Jim S., 07-25-2000 09:37:42
Compression test for All briggs, Take engine turn it by hand find the compression stroke , By pass it thru compression stroke , give it a whip counter clockwise if the engine rebounds from hitting compression , then it most likley has well enough compression to run
