Bolens Manual Deck Lift
Jay M
07-24-2000 18:09:07
Recently acquired a Bolens G14 (1453) with a 38 in. shaft driven mowing deck and manual lift. Is there a WWW source for a diagram of the manual lift mechanism? Mine only lifts about i inch when you get to the last notch. I'm presuming worn and very loose parts, but would like to see a diagram of the assembly. Is there a source of the year of manufacture (the tractor) if I have model and serial numbers?
Thanks for any info.
Jeremy
07-25-2000 10:20:30
 Re: Bolens Manual Deck Lift in reply to Jay M, 07-24-2000 18:09:07
Jay,
I have a 1453 with a 42" deck. I have the same problem - I only get an inch lift on the deck. I have learned to live it. I mow at the second to the highest cutting notch. I would recomend Sonny's Bolens web site listed below. There is a wealth of information and parts there. I also found a good Bolens club/classified site at Yahoo.com. Sorry I have no info on the deck diagram, but you should find the year of your tractor at Sonny's. Good luck!
