Clogging grass catcher on John Deere
Leon
07-28-2000 11:04:28
Anybody know any tricks to keep a grass catcher from clogging?
I have a John Deere rider with a rear clippings catcher. I mostly use the catcher to gather mulched leaves in the fall, and it works well for that. But whenever I try to catch grass clippings it ALWAYS clogs at the bottom of the chute.
Perhaps a different blade will provide more oomph? Wax the inside of the chute? Only cut grass on incredibly dry days? Give up?
I usually just blow the grass and it is not a problem, but I am trying to keep one section of the yard like a bowling green.
Kendall Kannegieter
04-02-2002 04:36:03
 Re: Onan B43G in reply to Kendall Kannegieter, 04-01-2002 10:32:55
Thanks for the help guys. You confirmed what I kind of already thought. My in-laws own a Cub Cadet dealership and last night we looked up the parts I need (a 982 uses the same engine) and their cost was more than I can buy the parts retail for at the local John Deere dealer.
Thanks for the help!
Kendall
dave(47 8n)
07-30-2000 10:57:43
 Re: clogging grass catcher on John Deere in reply to Leon, 07-28-2000 11:04:28
I had the same problem with the grass catcher on my Murry, now first I cut the grass with the regular shoot attachment and let the clipping dry a day or so then I run around at high speed with the catcher on and it picks up the clippings very nicely..
Dave
Vern Graham
07-28-2000 22:34:49
There are four types of blades available for the newer tractor/mowers, from very low lift to high lift. Only the medium or high lift blades are recommended for grass catchers.
p
07-28-2000 18:18:43
I have heard of some going slower, like REALLY slow.
Lou
07-28-2000 12:37:09
Cut when grass is dry, and not too long. Spray chutes & stuff with silicone.
Stop & keep unclogging. Take the catcher off and let the clippings lie.
steve zboray
04-02-2002 04:33:55
 Re: Bolens attachments in reply to Scott (PA), 03-01-2002 10:18:43
NEED 1050 BOLEN 3 POINT ATTACHMENT AND PLOW BLADE FOR TURNING SOIL OVER TO PLANT
