Cub Cadet won't start
Marty
07-29-2000 20:30:14
I've known for a while that my battery was getting weak, had to jump start whenever it was cold. But today while working on it I left the key in the on position without the engine running for about an hour without knowing it till I touched the hot coil. All the cells read 1/4 charge after a short charge but it doesn't even click at the key, not even while jumping with my truck. Any ideas. Did I burn something up or what? Thanks for any help.
John
07-30-2000 16:04:24
 Re: Cub Cadet won't start in reply to Marty, 07-29-2000 20:30:14
Sounds like all you need is a new battery. DO NOT jump from your truck which has a much larger battery and could very well cause your little shorted-out battery to explode,causing blindness etc.
Marty
07-30-2000 18:08:30
 Re: Re: Cub Cadet won't start in reply to John, 07-30-2000 16:04:24
Hey John, turns out I left the blade lever engaged so the safety overide switch was the problem. Makes me feel like an idiot!! But you're right I did need a new battery so I broke down and bought one, it'll solve a whole bunch of headaches. Thanks for the tip about jumping with my truck, I never thought about that!!
