BS 14 HP OHV Won't Start
Jeff
07-30-2000 16:15:02
I have a 14 hp BS OHV that acts like its out of time when you try to start it. It will pop thru the carb and thru the muffler. I'm pretty sure it has an ignition module. Is there any way it can get out of time? I've checked the key in the flywheel and the valves appear to be working alright, what times the module to fire? The spark plug has a yellowish spark when you turn it over. Thanks in advance,
Jeff
Don LC
07-24-2002 07:46:29
 Re: Farmall Cub to haul sailboat in reply to Scott from Cape Cod, MA, 07-21-2002 12:25:03
Get you a good running FARMALL H or M ....can be had for the same money and you won't need a winch....these tractors can pull 3 or 4 boats tied togeather,no problem.....
Chris ( Small Engine Man)
08-05-2000 19:47:42
 Re: BS 14 HP OHV Won't Start in reply to Jeff, 07-30-2000 16:15:02
Unless the Flywheel key is sheared the Spark timming is impossiable to get out of time with the new moduals, Try a New spark Plug that one might be Dead as a hammer, The yellow spark shows weak fire, Try new plug if still has yellow Fire to Plug, Remove if not still off the engine shroud Check the air gap Between the Flywheel and Magento modual, Take a index card place between the mag and flywheel, and this is pretty much the right setting for the air gap,Check the valve Lash, Make sure with engine on compression stroke, Both valves closed both rocker arms should have some movement to them, If not the Valve lash might be to tight, But yellow spark Leds me to belive that it is Spark related, E mail me for any more assistance i might be
john
04-26-2004 20:14:11
 Re: Re: BS 14 HP OHV Won't Start in reply to Chris ( Small Engine Man) , 08-05-2000 19:47:42
hi! i have a briggs that won't start.removed the gas tank and carb and cleaned and blew them out.it is on a pressure washer and is a 6.5 hp and is a intek 206.it also has a yellowish spark on the plug. how do i set the ohv valves and how hard is it to get the shroud off to check the flywheel? thanks---john
