1420 cub cadet mower wont turn on
BOB
08-02-2000 20:16:10
Can someone help me find a wiring diagram or offer any suggestions. I have replaced reverse safety switch and mower switch.
Bob
08-03-2000 19:29:41
 Re: 1420 cub cadet mower wont turn on in reply to BOB, 08-02-2000 20:16:10
The subject of my posting was unclear. My Tractor runs fine but I cannot get the deck started. It was switching off while cutting and now I cannot get it started at all. If I disconnect the two wires goin to the electric clutch should I get some reading on the amp meter from these wires? I was looking for any help to track down wiring diagram. I have replaced the switch and safety swiches with no luck. Any clues?
Jim S.
08-04-2000 05:59:53
 Re: Re: 1420 cub cadet mower wont turn on in reply to Bob, 08-03-2000 19:29:41
Yes, you should get a reading from the VOM set on Ohms between the two wires to the clutch. Test each wire with the VOM grounded, too. You should NOT get a reading from either wire when tested to ground.
There is a possibility that the clutch coil is opening the circuit only after the machine heats up, so you might want to mow with yer VOM in yer pocket until it does it, then test immediately.
Thoroughly check every stinking one of those bayonet-style clips in the circuit. They do get dirty and/or loosen the connection. Use contact cleaner to clean them, or emery cloth where you can get at the spades.
You can temporarily short across safety switch connectors to see if they are the problem.
Last, it may come down to running the wires and checking each with the VOM for a short. You can do this through observation without a schematic, if you are carefully observant of the color codes, etc.
But my bet is bad connector or bad clutch coil, if you have replaced the switches already.
Good luck.
Jim S.
08-03-2000 05:51:00
Bob, first go get a $10 VOM meter at Wally World. It'll save you replacing parts, cuz then you can test them.
If the problem is not caused by poor charging/dead battery:
Test yer ignition switch in the start and run positions with the wires disconnected. If it is not working in one or both, shoot contact cleaner in it from the back and work it, shoot some more and work it...do that 3 times or so, and test it again. That contact cleaner saves a lot of new switch buying, works for the safety switches, too.
If ign. switch OK, take a battery charger, ground it to the engine, and just touch the positive to the starter post for a second. If it turns over, starter is OK.
That gets you down to the solenoid or a short/bad connection in the wiring. Check and clean all your connections, including the ones at the battery. Any push-pin connections should be thoroughly inspected. Don't neglect to clean up all the ground connections, too.
If the battery is dead or you do not get good charge (should read 14 +/- VDC across battery terminals with engine running):
Test the engine charge coils by disconnecting the wire clip and checking ohms across the terminals (continuity). Also, ground one VOM wire to engine and check each of the coil terminals for shorts to ground (should not be any reading). If that's OK, it may be either bad connections (common) or faulty solid state regulator (less common). Clean ALL connections before suspecting the regulator.
The full regulator test is outlined in the Kohler Engine Service Manual from your dealer. There are several types of regulator, so I won't go into that here.
Beitz
08-03-2000 02:30:49
Make sure your magnet coils are not shorted (open)...
