Cub Cadet #1864
jasjr
08-03-2000 11:03:21
Is a kit or other method available to allow light weight riders (under 125#) to operate the tractor without the seat safety disconnets operating at every bump or turn? Thanks.
Jim D
08-03-2000 18:03:58
 Re: Cub Cadet #1864 in reply to jasjr, 08-03-2000 11:03:21
another option is to remove one of the two coil springs under the seat mounting plate. This keeps the switch functional yet it will be effective for lighter operators by reducing the "load" required to compress the springs enough to activate the switch.
(If you have access to a cut-off tool,you can remove one coil from each spring to do the same)
Jim S.
08-03-2000 11:25:29
Though not recommended by the Consumer Products Safety Commission, you could simply jump the wires leading to the safety switches, disconnecting them from the circuit.
