12 HP Tecumseh Engine
Charles Peters
01-19-1999 14:49:32
Had to work on the valves in this engine and am about ready to reassemble. Would appreciate an answer as to how tight the head bolts should be using a torque wrench.
Dave Beck
07-02-2000 17:42:46
 Re: 12 HP Tecumseh Engine in reply to Charles Peters, 01-19-1999 14:49:32
if You set speed control to run engine doesn't respond it just idles a little faster ,when You put blade and transmissio in gear it just speeds up a little.I can push the lever from the governor spring to governor and engine will accelerate.This engine is on a Murray 38" mower. Thanks Dave Beck
Bob Van
04-28-2002 05:34:23
 Re: 2182 Cadet in reply to Dave T, 04-26-2002 18:55:49
My source says it is 21 hp. and was built from 1990 t0 1993. Some also had 3 cyl. Kohler with same hp.
Pat Weepie
01-19-1999 22:21:23
Charles
According to the Massey Ferguson service manual
for the MF-12, the cylinder head bolt should be
torqued to 200 inch-pounds and in this pattern. 6----- ----2----- -----9 3----- ----- ----- ---- 4----- ----- ----- ----7 ----- -----x----- ----- 5----- ----1----- -----8
x = spark plug. Pay attention to proper length
/location. The book also says to retorque hot.
Best of luck, Pat from Alaska.
Charles Peters
01-21-1999 09:51:20
 Re: Re: 12 HP Tecumseh Engine in reply to Pat Weepie, 01-19-1999 22:21:23
Hey Pat from Alaska,
Thanks for the reply. Can I assume that if I'M using a foot-pound wrench instead of inch-pounds it would convert to 16.66 foot-pounds? When you said pay attention to proper length/location I assume you mean head bolt length. I notice two or the nine are shorter than the other seven.
Again, thanks much for your help!
Charlie from Franklin County, Virginia
