14hp briggs 1996 OHV
TIMOTHY KIDD
08-17-2000 12:47:56
I have been ahving a problem with the mower since one day it just lost power. I turned it off checked it out and restarted it and it ran but very labored.
The next time I went to use it it was very hard for the starter to turn over. It acted like it had 10,000lbs of compression. I took it to the shop and they did a tune up and valve work. I brought it home and guess what! It was doing the same thing. I Have not taken it back yet but I called them and they said it might be the carb! Can this be? If I put a charger on the battery(which is new)and keep trying sometimes it will catch and start and when it does it runs fine just the way it should. What can be causing this and can someone describe the repair to me.
Thanks,
tim.
jack
03-24-2004 21:27:31
 Re: 14hp briggs 1996 OHV in reply to TIMOTHY KIDD, 08-17-2000 12:47:56
I had the same problem with a MTD 14hpohv it was
the conecting rod on the crank I think ther is A
problem with that 14hp next time that happens re
move the spark plug and turn the crank by hand if
it still feels tight with no compresion its more
than likley to be internail your not the first pe
rson to have had that that problem with that 14hp
I just put A new crank and conecting rod in my dads mower
Jim
08-17-2000 17:58:57
Tim, is this a "Vangard" engine? I can't tell from your description why the "hard compression", but as for a loss of power... My vangard 16 seemed to be running rich all the time, with a loss of power. I went all through the carb, float and needles included, with no success. Then someone in this forum suggested I go UP one heat on the plugs...(I think it was from 12 to 14.. can't remeber). Wow... what a differece! Like a new engine. I only wish I had the name of the guy who left that note. Thanks, whoever you are. Good luck, Jim
Joe
08-17-2000 18:36:39
 Re: Re: 14hp briggs 1996 OHV in reply to Jim, 08-17-2000 17:58:57
i think that was me brigs had all sorts of problems with these engines they could never run right always fouling pulgs heads ovver heting they almost had a recall on them but i guess they haven't yet we have had brand new stuff come back with the problem you are discribing not just once 5 or 10 times back it's very frustratiog lots of dealers are just to lazzy to stock the right plug my boss sure is if you switch from the rc12yc to the rc14yc it will fix lots of your problems the valves may still be out of wack im not going to say but go to a diffrent store get the new plug and then tell your dealer that you did what brigs sugests that will blow his mind
