Good Greif i would say that is running way to danged hot ok here is somethings to check off the top of my head then i got to head out to my shop ignition timming , Check but unless your key is sheared i doubt Fuel mixture is lean,, well with boiling gas that would be hard to adjust carb as you already stated lol Thats Dayammmm hot pardon my french Oil Level im sure you have checked that so that minus that out They did a Valve job, Hmmm Wonder if the cam shaft is off one tooth one way or the other, And wonder if they even adjusted the valves like they should have after doing the valve job Dang it i wish i was closer to help ya out with this one ,, My Standard Question bout over heating is what i asked , Dont think i was downing you just checking ,, but whene a Carb Gets that danged hot id say shes running way out of line ,,,, Ohh Just Thought How far away is the muffler from the carb i know their never far far away just checking to make sure its not been bent extremly close to the Carb
