Bolens 1050 Need help.
Eric
08-21-2000 15:59:37
I been trying to solve a loud hammering noise and vibration in my Bolens 1050 driveshaft which runs the mower deck. I broke the tip of the pto. shaft off and also the roll pin keeps breaking. The driveshaft universal joints and the mower deck are in good shape. Any help will be appreciated.
Marge Burdette
05-12-2006 21:40:47
 Re: Bolens 1050 Need help. in reply to Eric, 08-21-2000 15:59:37
where can one order manual for the above garden tractor
Stan
08-23-2000 22:40:24
The front pto accessory shaft is out of round, probably due to bearings going out and superheating the shaft. Disconnect the mower driveline from the front shaft (just behind the two-belt pulley) and slowly turn on the pto. Watch the shaft as it begins to turn, and you will probably see what I mean. New shafts, bearings, etc. are still available thru Troybilt.
