Compression on Tecumseh HH 80?
rod
08-25-2000 10:23:02
What should compression be on HH80 Tecumseh engine also head bolt is broken off in block is the bolt hardened or can i drill it out.
thanks
rod
Small Engine Man
08-26-2000 17:16:09
 Re: Compression on Tecumseh HH 80? in reply to rod, 08-25-2000 10:23:02
Run engine for 5 minutes to warm it up , then install compression gauge, full throttle,crank over at least 3 compression strokes it should be @ 80 PSI Lowest according to factory is 60PSI
