Cub Cadet 1541 hydro problem
curt
08-31-2000 06:59:37
I have a 800000+ series 1541 hydro tractor. My hydro gradually got weaker over the last year, now it won't go up any grade. I bought the "bible" and it had nothing for checking the pressure etc. Have done the filter/fluid change twice. I emailed Cub Cadet and told them I am a technician and needed help, got a "go see your dealer answer"(I had already and Jed ner'herd nuttin'like that). Any info would be greatly appreciated.
Jim D
08-31-2000 15:02:09
 Re: Cub Cadet 1541 hydro problem in reply to curt, 08-31-2000 06:59:37
Curt,I have a suggestion which may be of help with your 1541. Remove the cover between the dash and the fenders. See the two hex head valve bodies(about a 7/8 or 1" wrench size). One is for forward,one for reverse operation. Try switching the two and see if it works ok on a hill now. Those valves sometimes go bad and require replacement. Had the same problem on an 1864 Cub Cadet similar to yours.
Tim W
08-31-2000 11:21:12
Curt, check the similar question from Bruce on 8/27 several threads below. Some good replys.
