Cub Cadet 128 Aux clutch R+R
ErnieD
09-02-2000 18:13:11
I have removed the two allen set screws from the front clutch assembly. Clutch is really stuck. Shop manual says to work off with two screw drivers...any other advice or secrets?
Deere Doctor
06-30-2002 19:28:56
 Re: JD STX 38 Mower Belt problem in reply to Sam, 06-30-2002 13:11:15
The small idler pulley's shoulder could be worn down if a plastic pulley,the new ones are metal and have a deeper shoulder.
Jim S.
09-02-2000 20:06:46
 Re: Cub Cadet 128 Aux clutch R+R in reply to ErnieD, 09-02-2000 18:13:11
There are SIX Allen set screws in the front PTO clutch. There are THREE holes in which these screws are located, TWO per hole. If you get them all out, you'll have a much better chance of getting it off the bearing. Otherwise you have no chance. I don't know what shop manual you are using, it should have told you that.
See my other post. I highly suggest you buy a reproduction of an IH Cub Cadet shop manual for your 128 manual, and save yourself headaches. Binder will ship to you in 2-3 days, if it is in stock.
