12 hp died on a hill
TomMurphy
09-09-2000 16:56:06
I have a sears 12hp tractor that won`t start. I was cutting on a hill when i ran the tractor until it was out of gas, it was running hot anyway . so I filled it up and it wounldn`t start. I removed the spark plug, reconnected the wire.I`m getting spark when I crank the engine.I tried a little starting fuild still no start. theres a bolt under the carb. and gas came flooding out. I know theres a safety switch under the seat but I don`t know how to check if its bad. I can`t think what it can be. any suggest?Murphys law strikes again!Whatever can go wrong will,at the worst possible time.
Dan Hersh
12-19-2006 09:52:09
 Re: 12 hp died on a hill in reply to TomMurphy, 09-09-2000 16:56:06
disconnect kill wires and strip them a little bit then put them together w/ a wire connecter.It should work.. Or check your fuses....it could be them
Linda Dudley
07-31-2002 14:57:40
 Re: lawn lion in reply to mark, 03-25-2000 16:17:12
We also have 2 lawn lions and cannot find out who made them or where to get parts for them. They have a bed on the back of them with a drop down tail gate. I would greatly appreciate any information on them or where to look. Thank you Linda
ironhead
07-31-2002 13:54:31
 Re: Re: Re: Re: Speedex model 1631 info request in reply to FRDMNN, 07-25-2002 17:27:54
everything is correct. and the 3 point is factory. i have the same tractor as you and other speedex's
sean faulkner
06-13-2002 15:25:16
 Re: Re: Dynamark 12HP in reply to Ray VanDervort, 01-22-2001 18:20:18
hi, i have the same problem with my dynamark 12hp 39 in. cut.. i would like to know where the blade engagment, or the foot pedel safety switch is i would like to know where they would be... thank, sean faulkner
paul b
09-10-2000 04:16:45
Sounds like you might have picked up a bit of crud from the bottem of the tank when it went dry. Some thing could be plugging the carb.
