16 HP Tech. locks up
Rich P
09-11-2000 11:45:14
I have a HH160 16hp Tech. new .020 piston installed,crank been ground and rod fitted it runs good but locks up at times when trying to start,only on compression.decompresser seems to be ok. any ideas?
don s
09-20-2000 20:23:52
 Re: 16 HP Tech. locks up in reply to Rich P, 09-11-2000 11:45:14
be sure compression release is opening exhaust valve at least .050 on tdc compression stroke..if not..check your valve adjustment and compression reease for defects.....don s
ROGER B
09-15-2000 18:24:04
TRY RESETTING YOUR VALVES. IT SOUNDS LIKE YOUR EXAUST VALVE HAS TO MUCH CLEARENCE, CAUSING THE DECOMPRESION TO NOT WORK. THIS SHOULD FIX YOU RIGHT UP.
JJ
09-11-2000 14:20:35
Starter or Weak Battery?????
JJ
09-11-2000 14:20:24
