Flywheels off! magnets loose
Jim M.
09-12-2000 13:01:59
I finally managed to get the flywheel off of the 13HP B&S engine on the Roper tractor we're working on. Didn't resort to a flywheel knocker, which the author of one book I read said could cause damage to crankshaft and/or crankcase. Instead, used a puller with Grade 8 bolts, an impact wrench, and whacked the puller shank after it was torqued down. Popped right off, a little anti-climactically. But three of the alternator magnets inside the flywheel fell off. Any recommendations of what to use to glue them back on with?
Beitz
09-12-2000 17:09:01
 Re: flywheels off! magnets loose in reply to Jim M., 09-12-2000 13:01:59
J-B Weld.....Not the quick weld...
Make sure you have the North and south where they belong.....
Look close ...You should be able to see where the magnets went and witch way...
Jim M.
09-12-2000 18:54:03
 Re: Re: flywheels off! magnets loose in reply to Beitz, 09-12-2000 17:09:01
Thanks for the suggestion. JB Weld sounds like a good choice. (I think it is basically epoxy with a high metal content.) I suppose I could use the strong, slow setting Duco epoxy I have. Are there two different versions of JB Weld? I've only ever seen one type for sale.
The magnets alternate N & S around the flywheel. I checked them with a separate rod magnet I had on hand. The original positions are really obvious.
Beitz
09-13-2000 02:07:48
 Re: Re: Re: flywheels off! magnets loose in reply to Jim M., 09-12-2000 18:54:03
Yes ... J-B has a quick weld thats not worth the time of day....
The regular stuff is super good...
