Bypass valve stuck on Roper hydro trans
Jim M.
09-12-2000 13:07:47
The hydro bypass valve on my Roper garden tractor seems to be stuck in the "not bypassed" position. Label says to "push in, then move to other position". I can push the lever in, but not rotate the valve. Any suggestions on getting it unstuck other than major surgery? What exactly does the bypass valve do, anyway? Allow the fluid to bypass the pump or trans, so that you can move the tractor without trying to pump fluid around?
