Fixing stripped bolt in cyl head
rod
09-13-2000 13:48:28
Is there a way to successfully fix a stripped head bolt hole in a 8 hp Tecumseh engine? threads came right off on bolt hole is totally stripped out.
thanks
rod
Beitz
09-13-2000 17:32:33
 Re: Fixing stripped bolt in cyl head in reply to rod, 09-13-2000 13:48:28
Depending on what bolt striped out....Somtimes you can get a nut under the fins and use a longer bolt... I have done this many times... There is about three bolts that you can't do it to...
Jim S.
09-14-2000 07:53:16
 Re: Re: Fixing stripped bolt in cyl head in reply to Beitz, 09-13-2000 17:32:33
Go to yer auto parts store and get a Helicoil insert kit in the right size for it. There's another brand called Big-Sert or some such. I always use the Helicoil product. It works fine.
rod
09-13-2000 19:47:47
Went back at it and removed a bracket that was on top also the two flat washers under bolt tightened it up there must be a bit of thread on left in hole. Don't know how long it will last like that but it runs again. Now looking locally for a replacement engine 10 hp Tecumseh was standard I guess.
thanks for the tips
regards
rod
Dean
09-13-2000 15:51:36
Yep, they are called Heli-coils. Get 'em at any auto parts store, some hardware stores.
Jim S.
09-14-2000 07:54:05
 Re: Re: Fixing stripped bolt in cyl head in reply to Dean, 09-13-2000 15:51:36
Dean, we were posting at the same time! :-)
Jim S.
09-14-2000 07:55:17
 Re: Re: Re: Fixing stripped bolt in cyl head in reply to Jim S., 09-14-2000 07:54:05
No we weren't.
