Electric clutch for 18 h.p. kohler gas engine
ROGER
09-18-2000 16:55:10
I BOUGHT A 317 JOHN DEERE WITH A BLOWN 17 H.P KOHLER. IT HAS A ONE INCH DIA. CRANKSHAFT. I PUT A 18 H.P. KOHLER ON IT WITH A LITTLE MODIFICATION TO THE MOTOR MOUNT. IT CAME WITH AN OGURA CLUTH ON IT. DEERE USED EITHER A WARNER OR AN OGURA CLUTCH ON THE 317'S. THE 18 H.P HAS A ONE AND 1/8 INCH SHAFT. I'M HAVING PROBLEMS LOCATING A CLUTCH THAT WILL WORK. ANY SUGGESTIONS?
Jim S.
09-19-2000 06:41:01
 Re: electric clutch for 18 h.p. kohler gas engine in reply to ROGER, 09-18-2000 16:55:10
Or, I just thought of this, pull your crankshaft out and have a machine shop turn it down to 1"...cheaper than a new crank!
Jim S.
09-19-2000 06:39:54
Roger, unless somebody comes up with a better idea, you may wind up having to switch crankshafts to one of the right diameter.
Herb Niewender
09-18-2000 22:37:20
E-mail Bill Klein at sandylakeimp@hotmail.com
Do you want to sell the 1" clutch?
dean
09-28-2000 16:45:11
 Re: Re: electric clutch for 18 h.p. kohler gas engine in reply to Herb Niewender, 09-18-2000 22:37:20
do you have a cub dealer near you if so : go to the dealer and get a clutch for a 1811 or 1812 cub tractor will work. cost about $225 complete. has 11/8"dia.
dean
09-28-2000 16:44:15
dean
09-28-2000 16:54:10
 Re: Re: Re: electric clutch for 18 h.p. kohler gas engine in reply to dean, 09-28-2000 16:44:15
don farris
05-06-2003 06:47:26
 Re: Re: Re: Re: electric clutch for 18 h.p. kohler gas engine in reply to dean, 09-28-2000 16:54:10
im looking for a rear eelectric clutch and pto assembly for an areins gt18 tractor to run an areins tiller
