Brakes on JD 317
John Elk
09-23-2000 08:42:42
The brakes on my 317 are not working well. They will keep the tractor from rolling down a slope but won't stop the tractor when in gear, just slow it slightly if you really bear down on them. They seem stuck. I haven't tried to take them apart, I'm a little intimidated. They seem like minature drum brakes, but that might be wrong. They also seem to be completely mechanical. Any advice from seasoned tractor men out there? I don't have a service manual. Any advice on procedure or thoughts about what might be wrong will be appreciated.
MrG
09-24-2000 06:44:43
 Re: Brakes on JD 317 in reply to John Elk, 09-23-2000 08:42:42
YOu certainly should get a service manual. The break linkage is supposed to be interconnected with the hydrostat linkage. When the brake pedals are depressed, the shifter for the hydrostat should be automatically returned to the neutral position.
If this is not operating properly, your hydrostat is continuing to push against the brakes...and those hydros are tough, they will override the brakes! Gadget
