Freeing oil rings
Rob Ray
09-27-2000 08:44:50
Hi All,
I have a 12hp Briggs on a Snapper mower that has set a long time. I've got it running good, but it uses a LOT of oil. The compression seems good, so I'm figuring the oil ring is stuck. I don't want to have to tear into it, so does anybody have a trick to free the ring up, like pouring something in the gas or oil?
Thanks for any help
Rob
Rob Ray
10-02-2000 09:40:17
 Re: Freeing oil rings in reply to Rob Ray, 09-27-2000 08:44:50
Thanks for the ideas - I appreciate it!
Rob
Rob Ray
09-28-2000 06:43:34
Thanks, Dutch. I'll give it a try.
Rob
dutch
09-27-2000 21:02:10
Try some ATF or Marvel Mystery Oil slowly thru the carb while running.
H MN
10-01-2000 05:51:40
 Re: Re: Freeing oil rings in reply to dutch, 09-27-2000 21:02:10
....I'll second the use of ATF in the crankcase..maybe even half & half for a while under light load. harvey
don s
09-30-2000 10:18:28
i have seen engines that had good compression rings and the oil ring was worn out....i have used automatic transmissin fluid in crankcase to clean out and free up old engines..you mix it one part trans fluid to four parts motor oil..the atf has very strong detergents in it...i learned this back in the 70,s from my uncle who worked at chicago cab company,,,he told me when they changed oil incabs,,they allways put one quart atf and for quarts of motor oil..... don s
