Fix JD212transmission?
Leon
10-01-2000 13:03:03
Starting to slip out of 1st gear. Are these trannys fixable--anybody had any experience or costs?
Jim WI
10-04-2000 10:59:59
 Re: Fix JD212transmission? in reply to Leon, 10-01-2000 13:03:03
I've rebuilt the transmission on a 112. I think they're pretty much the same -- especially since the "slipping out of first gear" is a common problem. This problem is caused by a small spring loaded detent mechanisim wearing.
If you tear it down now and fix it, the parts aren't very expensive. If you wait, the transmission will eventually slip out of first gear into two gears at once. This will probably break teeth on several gears. This is quite a bit more expensive (I think mine cost about $175).
If I were you, I'd be tearing apart that transmission as soon as I could. It's not too hard to do -- the hardest part is getting the snap rings that hold the hubs on the axles back in when you re-assemble it. It took me maybe 5 hours to do the actual work -- running for parts and building the stout bench that the manual recommended took longer.
Brian
10-07-2000 18:37:31
 Re: Re: Fix JD212transmission? in reply to Jim WI, 10-04-2000 10:59:59
Its probably harder to get it out of the tractor than it is to work on. You can go to JD and pay twice as much for the same parts as you can by going to a Tecumseh service dealer. The Peerless trans is a division of Tecumseh. Brian
Leon
10-05-2000 04:22:55
Thanks,I need to tear it down for some wheel painting and general clean up anyway. L
Jim WI
10-06-2000 11:02:12
 Re: Re: Re: Fix JD212transmission? in reply to Leon, 10-05-2000 04:22:55
I forgot to mention that if you wait for the transmission to break, it will inevitably happen when you are as far from the garage as possible. It's REAL fun to drag the tractor up to the garage when the wheels won't turn.
