Case 155 garden tractor
Wayne Davis
10-17-2000 11:40:26
Help, I need information, years produced, service manual, parts manual, where to get parts, tips on operation and service. I had one given to me and I want to restore it, because it looks so classic. I have several older Cub Cadets and the Case just looks good with them. Hydro-trans info would be greatly appreciated as mine wants to slip in reverse but seems ok in forward. I thought the pump fed the shift valve to make the hydraulic motor turn in the direction you shifted. A diaghram, flow chart,or parts break- down would help identify the problem. Thanks, Wayne
Max
10-18-2000 20:08:12
 Re: Case 155 garden tractor in reply to Wayne Davis, 10-17-2000 11:40:26
Sounds like the hydro lock valve on the hydro motor might be leaking by. A good source would be Ingersol since it is mostly the same people, different company name that was once Case, Colt, just located in a different part of town there at Winneconne(sp).
