Garden Tiller
Pulls to one side - any suggestions shy?
Alberta Mike
10-19-2000 19:37:15
Picked up an older garden tiller (5HP) at a good price at a yard sale, had to fabricate an idler pulley system, and the thing works well, BUT it has a tendency to pull to one side when I'm using it. Any idea why it might do this? The tynes seem to be lined up correctly.
Dan G.
10-26-2000 09:56:25
 Re: Garden Tiller - Pulls to one side - any suggestions shy? in reply to Alberta Mike, 10-19-2000 19:37:15
Could it be your operating technique? If one side is in "new" ground, and the other is digging where you've already been, it will try to go to the side, especially on a front tine type.
Mike M (RI)
10-22-2000 07:35:41
Like "JIM D" has already said check to see that the pin that holds the wheel to the axle has not fallen out...causing it to slip. The opposite side wheel will "push" the tiller to one side. It happened on my Troybilt just the other day! Good luck.
Jim D
10-20-2000 14:47:26
Front tine tiller or rear tine? Check that the drive pins are actually driving both sides of tines(and wheels if a rear tine tiller)
rod
10-19-2000 19:53:58
pretty normal with tillers. Engine weight normally doesnt sit centered over tines.....
