Cub Cadet tie rod too short?
Dave
10-23-2000 07:33:04
What's the problem . . . my recently acquired Cub 108 in in good shape except when I tried to adjust the toe in (1/8") I ran out of threads on the tie rod ends. I have only 3 turns left on each end and still the tires toe out (1/2" wider in front than in the back measuring to the same center spot on each tire). The axle mounting hubs don't appear bent - like from running into trees, etc. Should I weld in a section to lengthen the tie rod or what?
Nick
10-24-2000 15:50:51
 Re: Cub Cadet tie rod too short? in reply to Dave, 10-23-2000 07:33:04
You could buy a used one from one of the parts dealers on the www.ihcubcadet.com forum. I just bought a really good used one last week for my 123 for $5. It came in perfect condition with 2 nearly new tie rod ends.
Beitz
10-23-2000 18:20:15
Sometimes you gotta do what you gotta do....
It wont be the first time....
Steve B.
10-26-2000 13:51:52
 Re: Re: Cub Cadet tie rod too short? in reply to Beitz, 10-23-2000 18:20:15
Spindle is bent. Typical problem. Either lengthen the tie-rod or identify and replace bent spindle.
Steve
