Cub cadet rear bagger
don
10-26-2000 12:37:28
Does anyone know if a rear triple bagger made for a cub lawn tractor would fit on a cub garden tractor? Lawn tractor was a 1989 (yr) 1715 or 1720 with a model 446, 46" deck. The bagger is a model 445 made for this machine and deck. My machine is a 1990 (yr) 1541 garden tractor with a model 336, 46" deck and calls for a model 335 rear triple bagger. Would this be compatible with my machine in any way???
Thanks
Jim D
10-28-2000 12:55:06
 Re: cub cadet rear bagger in reply to don, 10-26-2000 12:37:28
The mounting brackets were different but you should easily modify them to fit the Garden tractor type frame. The bagger itself should work fine on it,be sure to get the high-lift "bagger" blades for the deck to make it work well. The baggers are nice on the 46" decks! You could still order the bracketry to fit it to the 1541 from your CC dealer if you prefer.
