Cub Cadet Stuck Engine
mike
10-31-2000 05:32:30
I had a Cub Cadet that I rebuilt and had rebored to .003 over-I thought. I posted for ideas about 6 months ago why the engine was so tight and got good input. Thanks to all who took the time to answer my quesions. The problem, as it turned out, was the nitwit who bored the engine was .0005 off and the cylinder was too small and caused the binding. I guess this is a good lesson to check everything before you put an engine together and instaall in mower.
Mike
Jim S.
11-01-2000 11:12:53
 Re: Cub Cadet Stuck Engine in reply to mike, 10-31-2000 05:32:30
Mike, some of the smaller Kohler engines (161/181) used two different diameters of piston, and so it is also possible you had the wrong size piston in the hole, especially if it was a new piston. The Kohler Service Manual spells it all out in the specifications.
My machine shop guy will NOT bore a cylinder unless he has the piston to be used right there with him to stick a mic on. It's a good practice to follow, a sign of a conscientious machinist. Next time, if your guy doesn't ask for the piston to be there, be sure it is, anyway.
Richard
11-02-2000 09:30:04
 Re: Re: Cub Cadet Stuck Engine in reply to Jim S., 11-01-2000 11:12:53
The shop I use has the same policy. I take the block to them they clean and inspect it and tell what diameter it needs to be bored to and them the pistons are purchased and given to the machinist prior to boring. Several times I have found that the parts in the box were not what was marked on the box.
