Ford LGT 165 Tractor
Ron
12-11-2000 16:09:53
Complete LGT 165 Tractor for parts With 60 " mower Deck , Run's great until Steering colum went bad ; or if someone has colum , would be much interested Thank's Ron
Andrew
04-14-2002 12:49:56
 Re: Walk behind help in reply to Jeremy, 04-14-2002 10:39:28
That is a Wards tractor. The engine is not original if it says Db on it or the gas tank has been replaced. The David Bradley tractors had bigger tires, bigger tranny and a regular car type clutch, not a belt tightner clutch. Those wards are really nice tractors though.
Andrew
BTw here is a club on those tractors
eric in vt
12-18-2000 17:16:04
 Re: Ford LGT 165 Tractor in reply to Ron, 12-11-2000 16:09:53
Hi,
I was able to adjust my 165 steering a couple of years ago. From memory, the steering shaft has a round gear that meshs with a toothed sector gear. First adjustment is to loosen a couple of bolts and move the sector gear tight against the steering shaft gear. That didn't do it for me- the steering shaft gear was too worn. I was able to shim the entire steering shaft up a bit with two thick washers. This allowed a new, unworn part of the shaft gear to mesh with the sector gear. That took out 75% of the play.
Hope this helps.
eric in vt
Brian G.
12-18-2000 20:47:43
 Re: Re: Ford LGT 165 Tractor in reply to eric in vt, 12-18-2000 17:16:04
Eric, I think you're speaking of the '70 and earlier tractors (prior to the LGT designation). They had exposed gears which are relatively easy to work with. The '71 and later LGT tractors have an enclosed gearbox of sorts that doesn't lend itself to repair as easily.
JCS in Pitts,PA
12-18-2000 10:28:31
Does anyone know how to adjust the steering?? Mine is loose on LGT 120 or LGT 125
sammy the RED
12-12-2000 17:28:07
How much and where you at ?
Dave P
12-11-2000 16:23:36
RON I THANK I HAVE THE STEETING COLUM THAT YOU NEED IF YOU ARE INTERESTED YOU CAN EMAIL ME AT TRACTOR
tractor39n@yahoo.com I LIVE IN SOUTHERN IND. DAVE
Dave P.
12-16-2000 18:55:03
 Re: Re: Ford LGT 165 Tractor in reply to Dave P, 12-11-2000 16:23:36
Dave yes , please contact me ,,, do you have the steering unit I need ? thanks Ron
