Case garden tractor need infor
Jeff
12-12-2000 20:24:22
I have found a case garden tractor for sale the seller thought it maybe a 1978 the tractor has an 16hp 2 cyl onan engine HST 3 point hitch plow,dis,54inch snow blade and 44inch mowing deck there is no model number on the hood and I did not write down any serial number the sheet metal is not to bad needs paint and front tires are bad back bar tires are in good shape have any ideal what model it is and can one still find blades for the mowing deck where this garden tractor made by case or some one else what is the tractor worth
Max
12-19-2000 19:59:00
 Re: case garden tractor need infor in reply to Jeff, 12-12-2000 20:24:22
Depending how you plan on using it and how much you plan on spending really determines the value for you. If this unit is a 1978, it should have the oil reservoir above the cooler in front. One of the downfalls for these units is that a log splitter can't be used. For this reason I like the later models for that Case log splitter is one heck of a unit for there is no cycle time since it splits both directions and some were available that would sit on the ground allowing the log to be rolled up about 10 inches and then its splitten time. If your not interested in the splitter, you'd never notice a difference between the units. Another point is to go with a good quality belt that is reinforced for you'd be lucky if you got three months use out of them otherwise. The Case/Ingersoll belts should last three seasons easy for that's what I average with my 48" deck. If you decide to buy it, take the transmission off, remove the top cover and check the differential bolts. If the unit used the Blade much, these grade 8 bolts have a tendency to break and end up going through the transmission case. I don't mean to confuse or discourage you from one of these units for I really like the two I got and would recommend them in a minute, but I think a person has the right to know what may go wrong with them in time. Believe it or not, the two I've got are 1981 and 1985 model year 446's and they're still on the original set of points, and I've only changed the plugs once in each of them. Good luck on your decision.
jdgcase
12-15-2000 18:13:11
If it has 16" rear wheels it is probably a 446. If the rear wheels ar 12" a 226. Check the link for photos of each.
jdgcase
12-15-2000 18:15:28
 Re: Re: case garden tractor need infor in reply to jdgcase, 12-15-2000 18:13:11
Here is the link
http://w3.one.net/~wduck/
john kerr
12-29-2002 19:26:36
 Re: Re: Re: case garden tractor need infor in reply to jdgcase, 12-15-2000 18:15:28
I this is john from pa i own a 155 and i am looking for a snow blade set up for my 155 does anyone have any info that could help find one thank you
jeff
12-17-2000 21:26:34
Yes the rear wheel are 16 inch do you think the tractor would be worth $1000.00 thanks for all the infor
Tim Schultz
12-14-2000 10:56:44
Sounds like the 446. The 448 had a 18hp onan. They are now Ingersoll and all the parts are still availible through them. Would you like to sell the three point hitch? I have the 448. The model # and SN on mine are located below the steering wheel and to the right of the brake release lever.
Andrew Waller
12-13-2000 04:55:59
Sounds like it is a 446 or 448 with 16hp Onan. I presently work on a 444 and it has a 14 hp Kohler
